āMaximum effectivenessāā¦ what does that mean?
AEBL and 3V are simply different with regard to their material properties. Both are extremely tough. AEBL is more stainless. 3V is more wear resistant. 3V is much more expensive, not only as a material but to process, i.e. more time grinding and finishing, more consumables used in the process.
If you want something unbreakable during high impact use, then no its maximum effectiveness gets worse as hardness increases. And so does 3Vās. If you want something with higher edge retention, then yes AEBLās maximum effectiveness improves proportionally to hardness, while itās toughness decreases.
AEBL at 60 is relatively low wear resistance compared to CPM steel but its toughness is outstanding. And that toughness and low wear resistance combine to allow edges that are thinner and thus cut better, even when dull, with significantly less chance of chipping during hard use.
They are easy to sharpen, not only because they respond better to the stones, but also because thinner edges have less materiel to remove in order expose a fresh apex.
AEBL anywhere from 60-63 is great. All within a range were its toughness and ease of sharpening lend it to thin blades designed to cut and be easy to maintain. And with edge retention more than sufficient for at least a day of common cutting tasks and minimal maintenance required to keep it cutting and with anywhere from best in class (60) to very good (63) toughness for a stainless blade steel.
Iāve been approached a number of times by folks asking me to use 3V to make a big chopper. Being a ādo more with lessā kind of guy for my whole life, Iāve never felt this was the right use of the material, and Iāve always said so when asked about it. Recently I got set up to make a couple medium choppers with it but even then the customer and I ended up agreeing on AEBL, and from an economic stand point, I think that is a wiser choice.
So when I do eventually design a knife for 3V, itās going to be one that I feel good about presenting to the world, that I can feel justified in the price I have to ask for it. Big choppers, in my opinion, donāt need the kind of edge retention that 3V offers. They are not being used to cut carpets. Whatever I design is going to be something that actually uses the steelās properties, thus justifying its cost. So Iām going to need to come up with a knife that calls for high toughness, exceptional edge retention, and has no need to be easy to sharpen. And thatās no knife Iām aware of at this time, so I might need a little help with ideas.
This is my opinion, and you may better understand why it has taken me half a decade to finally be willing to try 3V. Who knows, after using it once in āthe right knifeā, my opinion of it may change and I may see other uses for it that at this time I do not. But letās not get ahead of ourselves.
