- Mar 15, 2013
Hi everyone just sharpened the first of three fixed blades im working on and decided to test the edge. got shaving sharp with normal effort felt like fairly hard steel. knife was quenched in pre heated canola oil and tempered twice for two hours at 400-420 degrees (sorry toaster oven wouldnt hold 425 i was aiming for) temp verified with thermometer. had maybee 1/16 " of steel before ht and then ground with norton blaze 120 grit till almost had an edge and finished with stones by hand. ( 30 degree inclusive scandi grind) now like i said it cut very well and still does. shaved hair after medium stone no problem. cuts wood shavings easily and well. the only problem i had was when trying to chop with reasonable force( not a full on swing just a little swing from say 6-8 inches away. going into the end of a block of pressure treated lumber. so just like battoning with the grain and had the edge roll what i would call relatively significantly on about 1/4 inch of edge roll was easily straightened with a steel and knife still cuts well with no chipping. is this normal? or did I do something wrong along the way. I was carefull not to overheat the steel during grinding post ht but is it possible that as the edge got very thin it heated too much? any suggestions or input would be greatly appreciated.
Thanks all.
Thanks all.
