Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Marko3-
quint- I had a uniform color throughout the blade of a bright red orange and the " shadow" that runs throught the steel had all but completely dissipated I believed that this meant the carbon was completely in solution or had completed the transformation into austenite. please correct me if I am wrong. I had already passed non magnetic and would say that the steel went approximately two shades brighter/ lighter
The "shadow" you see has nothing to do with martensite vs austenite. It is the cooler core of metal in the thicker parts of the blade. If the blade was non-magnetic, it was all austenite.
When heating in a forge, the thin part ( edge) and the surfaces will heat up faster than the thicker middle and spine area. This is due to the rather low coefficient of heat of steel. When forging, this is good, as it allows you to hold one end of a bar of red hot steel in a gloved hand, and allows localized heating. In HT it is a problem to deal with. You have to hold the blade at an even temperature long enough for the whole blade to get up to the target temp ( say 1475F). In an open forge, the edge will continue to heat up and go well beyond that temp as the core heats up to look evenly colored. This is because dark red and cherry red look very different, but cherry red and yellow red look nearly the same. With 1084 it is best to look at the edge area when the blade becomes non magnetic and then heat to one shade of red more. At this point the edge area will be pretty close to the perfect temp. Quench immediately. If you can control the heating in your forge to some degree, holding it for a minute to even out the color ( get rid of the shadow) is OK, but it will be best to just quench once the edge is at the temp you want. After all, it is only the edge that we need hardened perfectly.
Here is a trick I use when doing HT in the forge. Once the blade reaches non-magnetic, I put it back in the forge and put the edge right against the side of the forge. This keeps it as much out of the flame as possible, while the spine and bevel heat up a bit more. With good timing, the rest heats up and the shadow disappears about the same time it is one shade brighter red. At that moment I pull the blade and quench.
