t1mpani
Platinum Member
- Jun 6, 2002
Received my own JY II today (had the day off) and really do like it. Blade geometry is very good, much better than the usual "tactical" folder fair, and while I have nothing against assisted openers, the unassisted-assisted opener (or "flicker" as I'd call it) on this knife is very easy to use, and I can see how it'd be a nice alternative, due both to its simplicity--the more complicated a mechanism is, the more that can go wrong--and since AOs have been lumped in with switch blades as illegal in some places.
Hangle ergonomics are very good, much better than I honestly thought they would be. The hand is definitely encouraged to be in pretty much one position, but it puts the edge at a nice angle to your wrist that would make long term cutting fairly comfortable I would think. Lockup is solid, and there is lots of room for the liner lock to wear in, I don't think it's even half-way covering the thickness of the ricasso where it currently sits. Haven't used it for anything yet, but my initial impressions are quite good.
EXCEPT for the pocket clip. I didn't think I'd care for it based upon the pictures and boy was I ever right. I carry knives of this size behind my right hip in my waistband, as it's comfortable both sitting and standing and I also don't have to get around the knife to get to my keys in my pocket. With the "ears" on the sides of this clip, my belt was being pushed out into a very odd and noticeable shape, not to mention that it needed to be loosened up a notch to be really comfortable. Plus, squeezing slightly hard with my index finger like I would if I were trying to carve something, strip a wire or do anything involving some precision, the bottom point pushed into the underside of my fingerjoint...this just wasn't going to work. Plus, I'm sorry, it just looked slightly garrish to me.
Well, I didn't have a torque wrench small enough to remove the clip, so I just stuck a shim under it to hold it away from the handle and give me room to work, and was able to pull the ears off and shorten the AOL a bit to give a more rounded, subdued appearance. Most importantly, it's one hell of a lot more comfortable IWB and in my hand. Left just enough out on the end to have a lip up, and it still slides over jean-thickness material very easily, but doesn't hang down so low. In fact, with a medium-wide belt, the clip almost completely disappears now. I left just enough of the old contours to make it look like the clip was built to match the lines of the knife, but may end up smoothing all transitions and just having it entirely straight--although I don't have any more room on the end.
http://s150.photobucket.com/albums/s115/t1mpani/?action=view¤t=IMG_0162.jpg
Anyway, I'm happy with it
Warren
Warren
