Yeah, purpose built. For tacticals I don't see it doing well (in general) as there you need a heavier edge and then you have inherent stability and thus you just go with 154CM+ class steels. This of course has been done to death with the many S30V vs 420HC comparions (would anyone even debate that now) but the point remains that 420HC has a much higher edge stability inherently. It will be interesting to see if threads like this induce people to stop with the "AUS-4 is junk" threads.
..... exposing my ignorance
(I am definitely outclassed by the real steel experts here) -
many of us are led to believe generally the higher the carbon the better the steel -
hence the desireable (and marketing) term "High carbon" used in stainless steels.
What this long thread had me seeing is that generally
"not so High" carbon stainless steels seem to have higher edge stability -
case in point -
Sandvik 13C26 - C=0.68%, Cr=13.0%, Mo=0.70, Ph=0.025, Si=0.40, S=0.01, HRc=57-59 (for Kershaw)
Another blade steel that seems to have a reputation for attaining good sharpeness and good edges is the Victorinox SAK steel -
but also well known to be on the "soft" side at only 56HRc
Vic SAK "INOX" steel - C=0.52%, Cr=15%, Mo=0.50, Mn=0.45, Si=0.6, HRc=56 (for Victorinox)
other steels mentioned -
420HC - C=0.4-0.5%, Cr=12-14%, HRc=55-57 (=58 for Buck)
AUS4 - C=0.4-0.45%, Cr=13-14.5%, HRc=55-57 (for CRKT)
My impression is generally the higher the Carbon content - the more difficult it is in keeping the grain/carbide(?) size small,
hence the high edge stability in lower carbon content - that of course means less edge holding/wear resistance.
However as pointed out before (in this thread and elsewhere) blade and edge geometry can have "softer" steels cutting as well as harder steels .......
Which brings me back to a long held belief of mine that good blade/edge geometry is as important (if not more so) than the steel,
and when it comes to steel I think I have a preference for high edge stability and the ability to get good clean sharp edges over mere hardness or edge holding.
So IMHO - a medium-high carbon steel like Sandvik or Victorinox "INOX" steel coupled with good blade/edge geometry suits me better for normal general purpose EDC usage, than harder high carbon "premium" steels with not so great blade/edge geometries......
but then I am not really a tactical type knife person.
Vincent
http://clik.to/UnknownVT2007
http://clik.to/UnknownVT2006
http://clik.to/UnknownVT2005
http://clik.to/UnknownVT2004
http://clik.to/UnknownVincent
