. You dont want to have to have a warming fire, folks. that's a huge waste of your time and caloriies. The Innuit did not have a warming fire in their igloos, at -40F, for months on end. This show ends the day after xmas. The worst you have to deal with is a month below 0F and 2 weeks below 20F So a double wallled, sealed tarp lean to, with a clear plastic wall, is all you need, and you probably wont need an outside fire at all. you definitely dont want a fire inside of your shelter! it's a major fire hazard and you're likely to later contract emphysema or lung cancer from breathing all of that smoke! To hell with that noise`
Just have head-sized hot rocks in pits under your raised wooden best, surrounded and covered with wood ashes. The ashes keep the rocks hot for hours. the covering ashes let you regulate the heat a bit, and prevent your debris-stuffing from catching fire. When you know to not bother with a warming, fire, you dont need the axe or the saw. A saw edge on the Cold steel shovel will suffice. This saves you one pick. You also wont need to waste a pick on the sleeping bag.
If you cant refine workable clay from shoreline mud, you dont belong on this show. Ditto if you cant make a fire with a bit of copper "snare-wire", duct tape, the head lamp battery, and then bed your coals in the ashes. two more saved picks.
If you know to take the rope hammock, you can make 5x as much cordage and netting out of it as you can take as the paracord and the gillnet. So that saves you yet another pick. As Kochanski said, "the more you know, the less you need".
Sam took a clear tarp for season 1 and there's no rules saying your tarp can't be reflectorized/metallized. So take the 12x12 tarp as half reflectorieze and half clear material, so you can set up a Kochanski supershelter, one layer, in an hour. You wont need the second layer, made out of a chunk of the 20x20 tarp. Stuff debris between the two layers of tarp, and tape the edges. Seal the shelter with the tape, so that your body heat and the heat of the stones is trapped inside of the shelter. When you are in danger of falling asleep, a couple of 1/4" holes can be opened in opposing sides of the shelter. This provides adequate ventilation. The 10x10 tarp can be folded in half, stuffed with debris, taped on 3 sides and you get inside of it. This is how you dont need the sleeping bag. you'll have 6 layers of warm clothing, ferchrissakes, as well as debris between each layer and you'll be up on a raised bed, with a thick layer of dry debris on the bed. You wont need the hot rocks until t's 0F or colder, and you wont need the Siberian fire lay outside, projuecting its heat thru the clear, vertical side of the lean to until it's -20F or colder.
