For the record, if anyone else is curious on how to boil water without a cook pot, it involves an arduous process by which you dig a hole, line it with rocks (though I bet this guy would use yet another piece of tarp) and then drop rocks heated in a fire into it. The problems with this method are manyfold, and absolutely hypocritical when coming from a guy who has stated you don't need a warming fire because it's a waste of calories. Let's go into it:
1. You have to dig a hole and line it with rocks (or with a tarp, and hope that you don't burn a hole in it)
2. You have to make a fire.
3. You still have to find some way to get water from a water source to this hole.
4. You have to find several stones.
5. You have to wait for those stones to heat up.
6. Bonus round: you have to hope you've found rocks that are the correct type, and not the type that tend to break up, or explode when intense heat is applied
7. You have to drop steaming hot rocks covered in ash into your water hole.
8. You have to keep adding rocks until a boil is achieved.
9. You have to strain water through a shamagh that you've got patches of rust on because you've used it as a firestarter
10. Drink
So, warming fire, a waste of calories, a hugely work intensive process to clean some water so you can drink (the number one critical element of survival: access to clean water)., though that's totally fine? Ok, then.
Incidentally, I know how much work this is, because I've done it in at least two of my survival courses I've taken. It's work, and all of this could have been avoided if you had just brought a cookpot.
Criminy, I feel like I'm having to step back into teaching mode here.
D
dahlia
if you use a different method, I'm all ears.
