daizee
- Dec 30, 2009
And she's done.
More pix in The Gallery:
That hatchet handle leuku looks good
That leather stacked puuko is so sweet!
I use a 240 grit to set an edge.
Also, the blue zirconium belts at HF and Menards last longer than the red aluminum oxide ones for wood. You can also order ceramic belts from tru-grit, Phoenix, or combat abrasives.
Thanks for the information. I'm playing with Machetes at the moment I bought the sander to work on axes but it's handy a lot of things around the house. I'm decent at edge geometry with axes/ hatchets.Zuul!!
Welcome back! Can't wait to see what you're up to.
plumberroy - yeah, what Vik said.
For axes I'll often use a 120 Zirc or Ceramic followed by an A100 3M Cubitron, but you won't be able to get those for a 1x30 (I don't think??). That little 1x30 is fine for brutish tool edges.
The main trick is getting the geometry you want. You can go right from a ~220 to a strop once your edge has a burr. That's a bit crude for a knife, but for an axe it'll do. I'd probably go one higher, but of course have a bunch of belts around.
Got my assorted pack of belts in. I put a 240 grit belt on my sander. I played with the one machete I've been tinkering with. Seemed to clean up the edge good fairly quickly
