Kinda sums it up perfectly. How can you reasonably use a folding knife without putting your fingers in the path of the blade? Except, of course, when opening or closing it?My fingers are always in harms way when i use a folder short of pinching up on the spine to make an exact cut. it's the reason the handle goes all the way around and generally has some sort of finger groove right along the channel where the blade nests when it closes. If I'm using a folding knife, then I am doing my best to use it so that pressure is put AGAINST the edge. The lock is just there for those times when I bump it or bang it a bit while making an awkward cut.
If it gets wedged in the material you're cutting and you're not very careful working the blade out of it.If I'm cutting with the knife: tell me how it could POSSIBLY fold closed on me.
This.you're not very careful
Well yeah... uncareful folks will tend to leak a bit of blood now and then.If it gets wedged in the material you're cutting and you're not very careful working the blade out of it.
Pro Tip: Try NOT stabbing that filter unless you need it to not be a filter anymore.Is it permitted to stab things with a folder? Sometimes I need to stab things. In fact, I did a lot of stabbing today. Dozens of times. Many dozens. Stabbing can put pressure on the blade in the unsafe direction. But I would most likely use a Cold Steel folder (or a fixed blade, of course) and I would not worry in the least about the blade closing on my fingers.
Sometimes I would have my fingers out of harms way just because I need to cut something in an awkward position, especially if I'm trying to take a selfie at the same time.
