- Mar 8, 2016
Yup only worry about the red stuff. As far as I understand (not much) the red stuff is active (living) rust that will continue to grow no only on the surface of the knife but eventually into the knife, if given enough time (years and years and years) it will completely corrode (rust is corrosive) the knife to nothing. Think of an old POS car left to rot on someones property for example, the red (active, living) rust will have eaten away and put holes into the metal, eventually consuming it all. Another example would be medieval swords, if preserved well they can be cleaned, documented, displayed etc but most have vanished due to the weilder being killed and perishing into the earth, his sword along with him.That definitely helps.
Gives me another reason to find more excuses to beat her up
Actually I had that experience, after using it some of the black does go away. But there is a section near the tip, almost like a black glare or a greyish area, that wont leave. If its not harmful to the blade and wont affect its performance than I am not fussed. Its just everytime I pay attention to it, I assume the worst haha
As far as I know the black (and rainbow, different materials have different effects on the steel, creating different colours) stuff is simply a patina. A little cover of *something, dont know exactly what* that has built up from chemical reactions of the steel coming into contact with any given material. Patina can rust, so can the steel. It is more rust resistant than carbon steels in my experience which is the reason some users like to force a patina as a protective layer over the steel. Rust can still grow on top of a patina which will then eat through it and the steel given enough time.
Both rust and patina can be removed via friction. A belt sander, some sandpaper and elbow greese or my favourite method, use. Splitting and chopping wood obviously provides a lot of friction where steel makes contact with the wood, removing both rust and patina given enough use.
Do some hard stabs into a stump of hard wood and that grey stuff will come off the tip of your knife pretty quickly. Unless it is decarb (again, need pics) then that is a different story...
