Cliff's comment is what keeps me off of many Spydercos, even though they are good knives. I'm not fond of the hollow grind either for most of my cutting. And even thin stock blades and a low grind height like Spyderco still cause me problems.
Phatch you must be one of just a few that have a problem with Spyderco's cutting ability. (if I read your statement correctly.)
Spyderco knives sometimes drive me knuts, with the likes of blade play vertically and sometimes laterally that is 'deemed normal' or 'within tolerance levels'.
At times I've had two Delicas and/or two Salts and/or two Enduras and one would have vertical blade play and the other would be rock solid but both were acceptable or 'passed' and both were new. At first it took me a while to get used to this and for the longest time it was why I absolutely refused to order any Spyderco on line or from a catalog.
If I couldn't play with the knife first to make sure it locked up right I didn't want it. But I finally lost my only knife dealer in town and had no choice if I wanted to own Spydercos so I took the chance and ordered on line. When I bought new I've bought from A.G. Russell, New Graham, Fred at Knife outlet, and more. When I buy used the first question I ask anymore is, "does the knife have vertical blade play when you open it?"
So far I've been batting about 50% or so with knives showing blade play in one way or another from Spyderco. My Manix, Chinook, CJ, Delica, Salt 1 PE and Native all had some vertical blade play from the minute they were first opened to my disappointment but over time I learned to over look that because the damn things cut so well and in most cases the blade play was noticeable but minute.
My current Salt 1 SE locked up so solid you couldn't make it move though, as does my Catcherman, and so did the Viele 2 I owned and the Para-Mil and the Tan Endura, and both my stainless Endura and my stainless Delica.
I tell ya, if these Spydercos didn't cut so good I'd probably not be using them to be honest because of this frequent blade play I've seen, but I read later that Sal said in Spydercos tests the locks held up better with just a tad of blade play compared to the ones that didn't have any play at all. I still have a big question mark about that to be honest.
Spydercos have such good edge geometry right out of the box that it is hard to find fault with them unless the vertical blade play is such that you can feel the blade move up with your thumb when you open the knife. Then I get irritated and in a couple of cases the knife was returned and replaced.
