I take it you have never noticed a barber cleaning a straight razor prior to stropping it.So I take it you don't believe that skin and hair building up on the edge of the razor are an issue?
Nobody said that, but it's not the only issue. Stropping is for refining an edge. The edge gets cleaned any time you strop. Both are true. Neither is "more correct".So I take it you don't believe that skin and hair building up on the edge of the razor are an issue?
As you have been told, stropping only fixes an edge that isn't very dull. It removes a small amount of metal. A very dull edge needs resharpening, although stropping would eventually work, but very slowly. ALL sharpening, if done correctly, leaves a clean edge, and I've found that cleaning gunk off the edge often restores cutting ability. When it doesn't, often times stropping does.Well it makes sense not to get the strop too dirty. It's counter-productive.
If we accept that both are true, then to what extent? I said earlier that even wiping an edge probably removes some tiny amount of metal, but it's probably negligible.
I don't think stropping is fixing the edge. For that to be true then it has to be removing a significant amount of metal, or perhaps straightening a burr without removing it. Now it can get hairy (pun intentional) defining what's a burr at a certain point (pun not intended). But strops are soft enough to wrap around the apex, so you shouldn't be able to straighten a burr with one.
As far as I can remember those barbers used some sort of towels to wipe those razors when shaving.So I take it you don't believe that skin and hair building up on the edge of the razor are an issue?
Rockstead brother.Essentially you are stropping your knife on your jeans my good sir..........
Little cleaning, more fine edge adjustment..!
That Japanese Knife company with the polished blades that I'm brain farting rite now recommends stropping on denim!!!!.
It works. My last step after the Wicked Edge is stropping on diamond loaded leather. Sharpness tests improve significantly.
(take it from me, I solved Wordle on my first try a couple days ago)
Rockstead brother.
Recently I've bought a nice fixed blade in 12c27n steel. This is my first knife made of this steel so I'm still testing it whenever I have some time.I have long suspected that all of the people praising the virtues of stropping for edge maintenance were unwittingly just cleaning their edges off on the strop rather than actually restoring the edge. I think they may have been under a false impression of what the strop was doing.
The only shortcoming I see is with so called toothy edges. After each refreshing on a strop you loose some of those teeth till you end up with a very refined push cutting edge.I can say, definitively, that stropping is an effective way to maintain an edge and take the shine out of the apex.
If one is not careful with their stropping, they may blunt the edge which they had properly apexed on the stone. (Rounding the very edge.)If I may add...
here and there I see a statement that you can round the edge if you strop too much and you loose the sharpness.
I must say I couldn't do that so I wonder if I misunderstood the word "round".
Do this mean radius on the apex (dull edge) or convexing the edge?
