- Jul 3, 2019
Yes, correct- I like fine edges, so I have no toothyness to loose.The only shortcoming I see is with so called toothy edges. After each refreshing on a strop you loose some of those teeth till you end up with a very refined push cutting edge.
If I may add...
here and there I see a statement that you can round the edge if you strop too much and you loose the sharpness.
I must say I couldn't do that so I wonder if I misunderstood the word "round".
Do this mean radius on the apex (dull edge) or convexing the edge?
Blues is right on both counts.If one is not careful with their stropping, they may blunt the edge which they had properly apexed on the stone. (Rounding the very edge.)
But stropping with abrasives can also be used to convex the bevel as well.
Stropping will invariably slowly convex the edge over time. This is usually rectified by a stone sharpening once there's some blunting that strops aren't going to expediently correct.
