- Dec 26, 2010
Great review! I wonder if it's possible to order one from CRK with blasted handles. I'm not a huge fan of stonewashed handles, they're a little too slippery.
I doubt they would do a special run in bead blast, but you could ask. There seems to be some future for this design with the announcement of the gear-pattern Ti-Lock. Maybe we will see more handle finishes?
Yes, I agree there would be no issue, other than that CRK has "its ways". Just like you can only get an Insingo with Micarta inlays, not wood, and that all Micarta scales must be bead blast, and all wood knives must have polished blades (that they will not stonewash), and you can buy a standard blade for your Insingo, but not an Insigo blade for your standard, and so on.
They seem to have definite rules about each knife, which maybe is a strength and defining feature of the brand. The rules changed for the Ti-Lock and I would be surprised if they would change them back, but it would be cool if they did that.
I believe the standard CRK answer will be "we are not a custom knife maker".
It would be insignificant to get a local shop to blast the handles if that is what you want..Would or should be pretty cheap to do. If I were going to go this route, I would tape off the areas I didn't want blasted myself.
I would imagine that, similar to other ti/bearing knives, the ti will wear a groove over time, creating a strain-hardened race with greater contact area with the bearings.
Good review, thanks for the mention kidcongo
The Ti-lock's differences from a "normal" integral, liner or lockback lock and its quirks are what makes it great.
It is the medium sized CRK. I agree, the blade angle gives it an advantage over the sebenza. David Boye and Matt Conable (WH knives) both have a similar bend in their pocket knives. I believe it helps make the knife more utilitarian.
I like the clip, it's a little bit harder to reclip, but it has great staying power...which is more important at this price range
When it comes to cleaning, I just use soap and water and kind of wash it in my hands with a good rinsing under the tap. After washing I've never had any debris left caught in it. I don't blow dry, just use cloth or paper towel and have had no rust.
Mine is 2011 and appears to have a finished interior, but I have not taken mine apart.
I would be worried about this inducing blade play, but I suppose if that happens there's always sending it off for a spa treatment, right?
Which is why the pivot is adjustable on this knife. You can take up the slack if any slack ever occurs.
As the race is created in the ti slab, it will very quickly stop wearing in, because you very quickly go from tiny contact points between hardened bearings and soft ti to much larger contact points between hardened bearings and strain-hardened ti. So, it's not as if the bearings are going to keep digging a path in the ti slab indefinitely. And as Kidcongo said, you can use the adjustable pivot to eliminate play. I would hope that CRK is anal enough in their designs to factor in this dimensional break-in, so that none of the geometry gets thrown off... but who knows.
Another question, I was under the impression that the Ti-Lock wasn't shipped with the traditional wrenches, lube and thread lock like the other models, but I've seen some recent pictures (birth date December 2014) where they were in fact included. Did CRK change their mind about letting people disassemble the Ti-Lock? I'm a chronic disassembler, so one of the things I've loved about my CRKs is that they are OK with you taking them apart, and I thought this wasn't the case with the Ti-Lock.
I too like to disassemble my knives to better understand their inner workings, & CRK knives as a whole are easily taken down, cleaned & reassembled. The CRK Ti Lock follows that same construction - it is extremely easy to disassemble & clean, and reassembly takes only a bit longer as one must be sure the ti lock 'barbells' snap onto the frame tracks. Very easy to do & really foolproof!! With the captive ball bearings, its even easier to reassemble without screw-up.
Yeah, I took apart a Benchmade 7505 once. After that, not much fazes me.
