So when I was trying to disassemble my WE 702 I ended up stripping the pocket clip screw, thanks to WE purposely designing the tool to round the edges instead of holding the screw in place. Anyways I tried using a Spanner #2 (SP2) bit which just ruined things more so...
Do you guys have any recommendations on how to remove WE knives stupid stripped hardware? I'm thinking about getting it redone by Josh and having torx installed. Thoughts?
Every job is easier if you have the right tools.
If I was doing the work: I would first take a center punch and deadblow hammer, place the center punch on the screw head making sure to position it dead center so that I don't just damage the "star flanges" when I then smack the center punch with the deadblow. This will break any loctite seal which might be making things more difficult. This little trick works just fine: I use it all the time to remove screws which are loctited in place, even if the loctite used is the red grade.
I would then put the knife in the Panavise so that it was held unmoving, and I had both hands free.
I don't know how much room there is between the star point and the inside of the countersink hole. I would purchase a pair of locking needle nose pliers with the thinnest nose I can find (doing a Google search, I found pliers ranging in price from 9.95 to $450.00. What I didn't find was a quick specification provided that told me the dimensions of the tip. However, with the current marketplace's liberal return policies, I would not worry about that, I would just buy something that looked close to fitting and try it. Assuming that I can't find anything that fits in a timely enough fashion, I would make my next move and try an alternate method which I know is going to destroy the screw. I would first take a fine-point sharpie, and mark a small spot on the screw and a corresponding spot on the scale - those marks line up when the screw has not moved. I can tell that I've moved the screw at a glance when the marks no longer line up.
I would keep the knife in the vise, grab my small chisel, and my deadblow. I would position the chisel as close to complete horizontal with the edge against a point of the star in a direction to loosen up the screw. I would then start tapping the chisel, quite easy at first, checking everything to make sure I'm not causing any obvious damage, and keeping an eye on my reference marks. Satisfied that I'm not causing further damage, and gauging the force I have been using, I would give the chisel a couple smacks that I think would be forceful enough to start backing out the screw. I would try serious force for maybe 3-5 times; if there was no movement, I would stop trying with this method - on the grounds that I don't want to break the knife.
I would now consider blowing off my deadline and looking for a better tool. I would probably try to hit a SnapOn truck. The older owner-operators have a lot of knowledge about tools, and are usually more than willing to make some recommendations.
If I got nowhere following the above, I'd give Josh at REK a call, describe what was happening, and hopefully he would take the problem on a priority basis. At this point - and this is just the way I am - I would pay his rate, and I'd toss in something extra for taking care of me.
I hope the above gives you some ideas if nothing else. Feel free to reach out and ask me any questions.
RLDubbya
