- Dec 20, 2021
Would you please describe how and why you spend this 80% (time, I assume) stropping? Are you using a progression of different strop compounds before the plain leather strop? Are you using powered grinding for the 20% sharpening work so that it is done quickly?I’m sure many have stated this before but I spend 20% sharpening, 80% stropping. A BESS tester completely changed how I go about stropping (with Vadim’s book of course). And hundreds of tests…
To start with, I probably stretched the amount of time spent on stropping. But my point was, in the powered sharpening I do spend more time stropping depending on how the blade is ground, and the steel of course. If I sharpen with a 1x30 belt stropping usually takes the longest. I strop on a 1x30 leather belt with various compounds. I test every edge on a BESS and don’t call them finished until I reach a sharpness that is typical for the type of steel I’m sharpening. Sometimes the honing/stropping process can take a while to achieve the refined edge I’m looking for. I freehand with the stropping process and the smallest variation in how I am holding the knife can make huge differences in results. If I sharpen on the Tormek, controlled angle honing really speeds up the process… unless I take it to a paper wheel. That takes time to get everything measured and set up exactly and still often need to make adjustments during the process.Would you please describe how and why you spend this 80% (time, I assume) stropping? Are you using a progression of different strop compounds before the plain leather strop? Are you using powered grinding for the 20% sharpening work so that it is done quickly?
