420J2 was never intended as a blade steel. Its used primarily because its very inexpensive...
In short, it is a poor overall blade steel, that has little business being used for knives, outside of a dive knife. MOST, but not all, knives made from it are of inferior quality.
I find it odd that some companies (one of whom has a name whose 4 letter acronym name rhymes with snickit) use a steel that most people would only use for liners as a blade steel.
Note, 420J2 is not to be confused with Buck's 420HC, which is actually a surprisingly good steel for the price point. In ordinary use, I'd say on par with 440C/AUS-8 for edge holding and a ton better than AUS-6/440A.
-j
What are your opinions on 440A steel? I know it's not great but I've never heard a review on it
My experience has really only been with CRKT and Spyerco's AUS-6, which the consensus seems to say is no different than 440A.
It's terrible. I honestly hate it. I imagine with a better heat treat it isn't too bad, but whenever I use it, it's as soft as, if not softer than, cheap kitchen-knife steel.
I remember (trying to) break down moving boxes with a CRKT AUS-6 knife once... held a usable edge for no more than three boxes (for those keeping track at home, that's 12 cuts at about 2 feet each) After that, it wouldn't even tear through the cardboard much less slice paper.
I've had better luck with the $4.99 Walmart paring knife, but that also could have been due to edge/grind geometry (i.e. very thin).
440C becomes useful... and then in every day use I don't really feel much difference between ATS-34/154CM/CPM154/S30V.
But I don't whittle, chop wood, skin animals... my use is primarily on cardboard and paper, sometimes drywall... YMMV.
I imagine on soft material like meat or veggies, AUS-6/440A probably does reasonably well for a longer period of time.
Hope this helps.
-j
The standard Kershaw Leek is 440A and I've never had any complaints with mine. Gets sharp pretty easy and stays sharp through normal use.
I agree 420J2 can get plenty sharp. Cliff Stamp conducted a review of 420J2 in a large fixed blade and it held up well.
420J2 has it's pros - very corrosion resistant, inexpensive and quite tough (especially for stainless steel) - those are the reasons it's widely used in many knives (mostly as handle material (and liners)).
