Its in my city too! Is this for your Suremak?
In other words, the big bolts that you tighten have to be on the left side. Put your wrench in your left hand. Lift the table to the approximate position you want and hold it with your right hand. Tighten the big bolts with the wrench in your left hand by turning counterclockwise. Make final adjustments to the table and tighten the socket head screw on the end of the arm.
When you need to change belt grits, just loosen the arm, pull it out a bit and change your belt. Don't move the table angle to change belts.
It quickly becomes second nature. Define your goal before you start moving stuff around and soon you will know just what to move, where, and when. Perhaps the first few times it might be best to have the AC/DC or Iron Maiden playing at reduced volume so all the brain cells get a fair chance to fire.
I does make a big difference. Don't ask how I know
Michael, do you think if I put a quick clamp instead of hex socket screw(that clamps the round bar)? Will quick clamp get in a way or it should be fine?
It would be nice to make adjustment totally "wrench free".
Michael, I hope you don't mind me commenting:
When figuring out how to build this, the need for the two left handed bolts became obvious. It was a very bright solution to a problem that showed up in development, and I was most impressed with Michael's insight. LH threaded bolts and the LH tapping would have substantially increased the cost, so making the bolts from acme rod and bolts was done to maintain cost threshold. Handles were considered, but, once again, cost is high and many people might be willing to use a wrench if it made the difference between having one and not. There are numerous solutions to handles and the user can always add his own. One important consideration is that this actually tightens as weight/force is added to the table. So, if you put something heavy on the table or lean in it, it will tighten. Put too short a handle on these, and you will have a harder time loosening them. After using mine awhile, I decided to stick with a large 7/8" offset box wrench.
You could have bent rods welded to the bolts. You could drill and tap the "bolt head", thread rod, and make handles to your spec. A quick solution I use around the shop is to buy cheap box/open wrenches (angled head on the box end), then cut the open end off and discard it. You can then use an adhesive to glue the wrench onto the nut or even have it welded on. Works great.
One thing to pay close attention to when adding handles: position them so they won't run into each other when you are loosening or tightening them. This is an easy way to cause yourself problems if you aren't using your noodle when you make them permanent.
Hope that helps.
Awendaw, SC, Dallas, TX, Killeen Texas, East Norriton, PA, Sunnyvale, Ca, Cumming, GA, Prescott, AZ, St. Louis, Mo, Canyon Lake, TX, Nashville, TN, Los Gatos, Ca, Grand Rapids Michigan, some where else, MA, cridersville, ohio.
Ready or not, there on the way!
Michael
www.adammichaelknives.com
