I'm with the majority on this one. Mini Bic.
Compact, lightweight, durable, reliable, lasts a long time, easy to use.
There are a couple mods you can do to the Bic. You can fit a small split ring through the air vents on the metal guard piece. That's useful if you want to put a lanyard on the Bic to stop yourself from losing it if it falls out of your pocket. You can also wrap a foot of duct tape around the base. Duct tape has a million uses. It works as tinder too. Something about the adhesive makes it burn well. Last but not least, if you put a small zip tie around the top so that it tucks under the lip of the red button, it will stop accidental leakage from occurring when the button gets randomly bumped into by something.
The Bic lighters with artwork designs on them are good for that. The designs are printed on a thin outer sleeve that's wrapped around the main body of the lighter. They don't even use adhesive, so once you cut it, the outer plastic comes off really easy. The main body underneath is always a semi-transparent white color. You don't need to use a flashlight to see the fluid level through it.I use yellow colored Min-Bics. Easy to see if dropped and easy to monitor fluid level by holding a small flashlight to the side of the lighter.
Ok ive read ALL the comments. and saw no one recommended the "Permanant Match"
these were used many years ago .. like a Zippo they require fluid/fuel. but the striker has a small piece of cotton/fabric
on the tip below the striker.. the rod/striker screws into the body. you unscrew the rod /pull out the striker and 1-3 strikes you have a fire on the
end of the metal stick.. i found these online and bought a 6 pack just because.. a couple of these with a small container of fuel would last you many years..
i dont believe these use a flint at all.. more like a small piece of steel to spark once stricken on the ferro rod on the outside of the caseThe flint for that permanent match.... as for a fuel Zippo...will calcify and become useless over time. So for either one you should carry extra flints as well as fuel. On my Zippo I keep 3-4 flints under the cotton.
I've not had any luck with these. The wick burns away when the fuel is finished and then you're screwed.Ok ive read ALL the comments. and saw no one recommended the "Permanant Match"
Bics are cheap, you can replace the just about anywhere and in my experience rarely fail, Ive drowned 'em swimming, blow on the flint, rub on your shirt, they still work, Ive pulled 'em out of packs that sat for years, still works, sure they have a limited lifespan but how long you spendin in the bush mate!?Keep it simple and inexpensive. Bic lighters . I like my butane lighters for cigar time, but a five pack of Bics go a long way.
Wow no bic lighters.?!..I thought I lived in a nanny state! In Vic AustraliaInteresting fact. It is next to impossible to find Bic lighters in the United Kingdom.
I have found one or two online retailers selling standard mimi packs, but no full size, no piezo models. You never see them in stores. Everywhere that sells lighters sells only the Poppel brand. Bought some, they are piezoelectric, took one on a jungle trip, it got wet and would not produce a flame until we were back home.
My guide on that trip complained about Zippo fuel leaks. He liked the various Peanut Lighters, but carried a Bic in an Exotac case, and an Exotac Nano Strike since the wet destroys unsealed ferry rods too.
Huh? Have you tried the big A?Interesting fact. It is next to impossible to find Bic lighters in the United Kingdom.
