Thanks for the excellent review and detailed photos, Yavol. I've never touched this knife, so I don't have any direct experience. And it looks like it is very well built using excellent materials and will fill a market niche.
However, from the peanut gallery:
This knife strikes me as a self-parody: too big and beefy to really be a useful pocket knife, like a bodybuilder trying to learn ballet. 99.9 percent of the time, a smaller, slimmer pocket knife will be more useful. The exception might be if you need a pocket folder to dig a hole. My guess is that most people would want to carry a second, smaller pocket knife if they really had a use for this monster.
Well said! I totally agree. :thumbup:
How well does it slice with the obtuse edge and all?
I like big folders like that but do these only come with AO? Is it possible to disable it? Law dogs around here frown about that. Any different in blade thickness with the 200 or does one cut better then the other?
* S30V steel is a joy to use. Razor sharp factory edge pops hairs. I don't mind the largish ~40deg flat grind for this knife application.
but it carries its bigness well.
You can disable the AO by taking out the torsion bar. It's easy. But that's one of the key selling points to the 0300 over the 0200. Why buy it just to disable it? The 0200 seems to have a similar thickness with less width; slicing will be just about the same. I'm convinced the 0200 is more EDC friendly had has better axis rotation and control (for smaller, detail work) over the 0300. If the 0200 had S30V steel I'd be all over that one. As is, the ZT0200 is a very very very good deal.
yavol
What types of uses do you have in mind for the knife? I have a knife in S30V that I took to about 8 degrees per side with microbevel that didn't see any damage in regular cutting. I took the edge down again to about 8 degrees inclusive and so far it still performs great. I'd imagine you could go to at least 12-15 degrees per side and still be able to handle most uses, unless you plan on cutting metal or similar abusive cutting.
...Military is nice but I like carrying a big rugged over built folder that can take some.
