- Mar 6, 2008
Pictures courtesy of T.A.D. gear.
I've had this knife for over a year now. Still running strong. Thought I'd post a formal review.
We'll start with overall first looks outta the box.
Totally B.A.! Razor sharp S30V steel, and they put an extremely polished edge on mine--really nice job on the edge.
Upon further inspection, the G-10 at first will seem quite grippy, but will eventually seem perfect--if you put in the small of your back, it won't scratch you, yet it is sufficiently grippy.
Full tang--it has notches toward the hilt and towards the butt of the blade--again, small enough to not bug you when you carry it against your skin, but are there to provide the perfect amount of grip along the sides of the blade which don't have the G-10.
It also has a lanyard hole in the butt, should you need/want one.
The torx screws that hold the G-10 to the blade are screwed in extremely tight--It will not come off under even harsh use.
The G-10 is very strong and impact-resistant--dropped it on tile, and didn't even ding the G-10, just a slight tile-colored mark!
Blade is a dagger--so it's Ambidextrous, should you need to use it with your weak hand.
Sheath--It has 5 eyelets for a merc-harness, should you wish to carry it under-neath a garment shoulder holster style.
It has Belt/tie-down slits, 5/16th's of an inch wide, two are 1 inch long, the other two are 7/8th's inches long.
Belt clip is some sort of flexible plastic--does its job fine for clipping to a belt, but I dunno about a boot--needs to be able to latch on something.
Underneath belt clip is a small space--enough room for sling type material.
Sheath has level 1 and 2 retention
Level one retention is permanently molded, small piece of kydex made so that it has good retention, but the blade can also be pulled straight out with decent force. You can also use your thumb to slightly bend it to take out the blade. (Opposite side of thumb snap in picture)
Level two retention is optional, it is some sort of a Metal-weaved rubber-coated strap. You can pull it to the side so that it doesn't get in the way of the level 1 retention kydex, or you can pull it over the blade so the you must unbutton it in order to draw the blade.
The edged blade is exactly as long as the handle--measured with ruler each 3 5/8 in.
Oh, almost forgot about the coating--it is insanely tough. "PVD" coated--physical vapor deposition or something like that. They do use that coating on pistols, I've heard.
One side note, the kydex sheath will mark the coating, but it can be scrubbed off with some soap.
Absolutely no negatives--I can literally attach it anywhere, (belt, IWB, 11'o'clock, vest, backpack, etc.) and can draw it with ease if needed. My only small preference change being the plastic clip--maybe a blackened metal clip would suit for belt carry more often.
EDIT 4/5/09: some comparison photos--sorry for the quick-and-dirty quality
Be sure to check with your local laws before purchasing--it is a dagger, and a nice one at that. :thumbup:
