I think the Pro will have a new clip. not sure of the standard model.
Do you have a pic of the new clip?
I modified the Pro, not the select, by grinding a bevel onto the attachment-plate and cutting countersinks around the holes and using beveled flat-head screws for mounting - not a perfect job but it is an outstanding improvement for ease of carry - knife slips all the way on and off the pocket much more easily without snagging threads of the seam:My main gripe about the clip is that the screws are not recessed. I modified this on my pro, will post pics this weekend.
I used T6 flat head screws (2-56) and the angle on the head matched the bevel angle on my 3/16 or 5/32" drill bits for steel, so used those to cut a bevel in each screw hole, then switched to a grind-bit to de-burr the holes. For the ramp, I used the flat face of a cut-off wheel - just set it spinning and brought the edge-to-bevel onto it.looks good. mind explaining more how you did that?
Benchmade Bugout, also on their little pocket sharpenerI'd still like to know what the small black clip was from in the original post on page 1.
Nice job.I can live with the factory clip as it does it's job, it's just a tad wide for me. Today I'm carring a Slim 110 Pro with the standard clip that I acid washed for a more subdued appearance.
