- Mar 12, 2013
What psi are you using on the paint gun?
35 PSI, that was what was recommended in the instructions for the gun, but perhaps it should be set otherwise.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
A tack rag will contaminate the steel. It is a good idea for wood, but not for this application. Sorry.
I have the same gun and shoot at 50psi. do you set the psi while you are pulling the trigger on the gun? do you get a buildup of paint on the atomizers on the nozzle? and what type of pattern do you set the gun for, tall or round?
The guy who coats my knives, cleans his gun like there is no tomorrow. He shoots his guns and my knives around 10psi. One coat.
That first pic of the three blade pics sure looks like trash is still on the surface of the blade before you spray.
I seriously doubt a paint brush, new or otherwise, is capable of removing all the trash from the blade. You ought to try a tack rag instead. With a rough surface you'll most likely need to "daub" with the tack rag instead of rubbing with the tack rag.
If it's not trash on the blade it could be trash in the mixing container, trash on the stirring stick, trash in the spray gun , etc. Paint filters won't necessarily filter out such things.
I don't want to add to your confusion, but here ya go.Do you start your spray off of the blade? A gun will give that spatter if you are on the part when you pull the trigger. Im also with J-Siah try 50 to 60 with your paint volume turned down and back off to 5-6 inches. I don't use a HVLP gun anymore, I like an air brush much better but I don't do high volume either.
I think you are not seeing those defects before the baking because of the solvent content in the paint film prebake. I suggest you sand the defects and look at them with a magnifier to see what color they are, it could be many different things. The plumbing on the compressor looks nice, if you do it again it will be beneficial to have 15 to twenty feet of hard line before your filtration. The air coming out of the compressor will hold contaminants in vapor because it is still warm longer lines give the vapor time to condense. The dirt nibs do not look like a moisture/oil in the air issue those contaminants look either like a crater if it was oil or a blister if it was water. Make sure you are using nylon mesh paint strainers not cloth, you could see about getting a 3m PPS system with waterborne cups (these have a much finer filter built into the lid. Waterborne strainers also have the fine mesh but the glue used to hold them together would dissolve in the solventborne paint. After you strain your paint into the cup look closely at the strainer and see if it has small clumps, this is referred to as seediness and could be a result of some old material. Your filter at the gun looks good and the pressure recommended by the maker is good, air pressure will only affect texture (orange peel) if it is too low or excessive overspray if its too high. The environment you are spraying in could be to blame, dust in the air can accumulate paint mist like the forming of a raindrop. I still would sand into the finish and look at the nib color, and check the strainer, your material could be bad or old when you buy it I have seen this with toners on a mixing machine several times.
One small point about the tack rags, they don't contain any waxes, oils or stuff like that. The cheese cloth is impregnated with a rosin that won't normally transfer to the surface you're rubbing unless you rub to hard. And never touch the blade with your fingers after you've cleaned the blade with solvent.
With an abrasive blasted surface you will be bore concerned with the rough surface snagging the fibers of the cheese cloth.
But for sure if you contact Cerakote, go with what they tell you.
Looking good Aaron. Since your in a shared workspace, would it be possible to corner off a small area? Before I spray, I put the plastic sheets up, blow everything off, and then about a half hour later I spray the entire area down with water to prevent any of the dust particles from floating around. In your case i would wait about 20 mins of running a dehumidifier to get the moisture out of the air, and then proceed with your spraying.
