For now I have two belt grinders .Both use 2x42 belts .One have gas spring tension other have ratchet mechanism . The one with gas+ steel spring tension/ over 44 lbs. together / have 22cm dia. drive wheel and after some test I make i concluded that I have belt slip . Other one have ratchet mechanism and only 14cm. drive wheel and it is impossible for belt to slip whatever I try .
Today I used this belt frequency meter/ I use that tool most for timing belt tension / to measure belt tension on both grinders.....I use Hz because to measure in Newton or LBS I need to enter mass of belt ......Here what data I get ..................
I try in newton without enter mass of belt ........
So if I take this data seriously I should use over 90 lbs in first one to get rid of belt slip on first grinder ?
