- Aug 20, 2011
Well, one way or another this thread sure was fun.:eagerness:
Kowing that the knife is clean and does not have residue sap on it is the issue ... prepare food with any blade which has any dirt or sap on it and you will get the "runs" ... happens all the time in the military with guys using coated bayonets which are hard to tell if they are clean ... the old SLR bayonet was my learning curve on this ...
In the field I always use a satin finish for food prep when cooking and use boiled water to clean the blade ... doing a gralloch or skinning game and preparing it I am happy using a coated blade ... it is handling/cutting the food after it has been cooked that you need to be careful ... or using a knife on none cooked food like bread or fruit ... cooking will clear up the risk of a bit of dirt on a carcass ... but slicing meat off a cooked carcass or cutting cheese is where problems start ...
Becareful if you have a tool steel blade where people tell you to do a forced patina ... these can be as difficult to tell if the blade is clean as a coated blade ... I experimented with these and then found when cutting white cheese that the cheese was tainted by stains ... not worth the risk of a dodgy stomach in the field ... nothing is worse ...
A seperate food prep knife is the best arguement for carrying a second blade for "survival" purposes ... and the extra weight is usually very little if you make a sensible choice.
