- Jan 26, 2018
Can anyone tell me if the browning black label duration is worth buying thanks
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Very badass
The general rule is that knives branded by firearm companies are promotional scrap metal, and you'd be better off buying a knife branded by an actual maker.
There are a few exceptions that I know of:
- Beretta (knives sourced from Maserin, Fantoni, and others, not fancy but quality)
- Oberland Arms (not sure of the maker/s, but generally competing in the midtech space)
- Wilson Tactical (collaborations with Chris Reeve, Les George, etc.)
Let us know what you think after some use please
Cool thanksThe general rule is that knives branded by firearm companies are promotional scrap metal, and you'd be better off buying a knife branded by an actual maker.
I had one of those. Two actually since they were cheap.This is kinda cool though still. Browning Black Label Vanquish. Krudo Knives design.
They come set up like you see, right hand carry, tip up, blade facing into the pocket. Meant to "open" as it's pulled from the pocket, which you can get it to do. Mine just opened in my pocket and I got cut. Moved the pocket clip to the other side and not it just sits in a drawer. I covered it's bases by getting a fixed blade karambit and a Spyderco Singh Khalsa for the "small everyday carry" (which obviously feels like and is a better little knife.) Anyway, not a bad knife, just not super well thought out, or at least requiring better detent for how it comes set up - although I would guess stronger detent would keep the gimmicky opening from happening. For a budget knife, it was no better or worse than other budget knives.
Sorry, might not have been clear. For the "wave" feature to work, the blade is tip up, spine facing the inside/groin side of the pocket (i'm sure you know this part). I put my hand in my pocket, and because the detent was not good or whatever, the blade was half open in my pocket and I got cut. It was not an error in it doing what was intended (the draw), it was a problem with it doing something unintended (just coming partially open in my pocket.You have to be careful with knives that have a wave feature like that. They are obviously designed to open when draw. If you want to draw the knife without opening the blade just block the opening by putting a finger on the spine of the blade.
Back in the day Browning had knives made in the U.S., then Germany and Italy, then Japan. Like so many other brand names, they have gone the way of so many other names in terms of low cost production and country of origin.
hattoricollector.com/2015/09/28/browning-hattoris/
Beretta also had knives made in both Italy and Japan. Even Smith & Wesson had some beautiful knives made in Seki, although the exact contractor is unknown.
http://hattoricollector.com/2015/10/01/beretta-and-valor/
Absolutely true that in general, today it isn't worth even considering knives with firearms maker brand names.
I'll stick to normal tip up/tip down blade towards the hip from now on.
