Busted my customized BK-9
Id start by trying to make it into a modifued “tracker” design. You would inly have to remove the material behind the chip towards the handle first. If it worked out, you’d be done. If not, then you only have the front portion to continue grinding on.
Good luck!
If you have a decent way to grind, I'd make something with less belly. Something more stabby.
More use of original blade that way. You can always shorten it later, if needed.
Wow that's quite a chip! I'll be interested to see it after you grind it.
Reminds me of one of the inspirations of Ethan’s handles…
