What's a good way to clean up the scales on my Military? I have some dirt lodged in the texture of the scales. I was going to try a stiff brush but didn't want to scratch anything.
Rasco nailed it. Seriously, try the Mr. Clean Magic Eraser before you try anything else. It cleans up G10 like it was made for it. Not only that but it isn't messy like WD40 or Ballistol. Just add water, rub and wipe off.
This was a Bob Lum Tanto I bought from a store. It had been handled a thousand times and had changed color. You can see what it was supposed to look like under the clip I removed.
This is what it looked like after a minute with the Magic Eraser.
Plus water
Here is a slightly interesting Wiki article about melamine foam, which is the stuff that Mr. Clean calls Magic Eraser. You can buy generic "Magic Eraser", i.e., melamine foam, on the interweb at a cost saving over the retail stuff. Rock on.
I've found that WD-40 does a great job "refreshing" and cleaning G-10 and Titanium. Using the straw, If the spray doesn't flush out the dirt a soft bristle brush should do the job. Or you can just use soap and water but remember to oil after.
Best of luck!*
A stiff brush is not going to hurt G10 at all, in fact an old tooth brush works great.. Try using a Mr. Clean eraser with a little dawn dish soap or Bar Keepers Friend.What's a good way to clean up the scales on my Military? I have some dirt lodged in the texture of the scales. I was going to try a stiff brush but didn't want to scratch anything.
Can you get that foam from a local hardware?
