- Feb 6, 2007
Wow, I’d like to get one of these as well!
They are $115 without any attachment. I will let you know about the UF1 when I hear back from Chad.What’s the cost on these and are we thinking they’ll hold a UF1 just as well?
I sent an email, naturally replying to a different order and not mentioning my post number, sorry about that.The sheaths for these will be $115 plus clip if you would like a clip. $60 upcharge if replacing the kydex sheath
The clip is completely optional.
Spyderco G-clip, Discreet Carry Systems 3.1 mini, and Ulti-Clip Slim for $12 each or a Mummert clip for $20.
If you send me an email, please try to reply to the original preorder email or try to include your post number if possible.
Thank you!
Jo
No problem! I just replied. They are available in your choice of black or brown.I sent an email, naturally replying to a different order and not mentioning my post number, sorry about that.
My question is whether they are also available in black, or only the brown that you showed?
Hi Josh! Per Chad- "It fits fine and is almost as secure, it doesn't have quite the same snap in for mainly because the thumb ramp sits back a little further on the original. The original also has a bit more belly towards the tip so it bites a little into the welt, but I leave plenty of room so it won't cut the threads. I don't usually recommend switching between models but this is as close as I have seen on being fine with it..."What’s the cost on these and are we thinking they’ll hold a UF1 just as well?
Thanks Jo, replied to original order email with post #.The sheaths for these will be $115 plus clip if you would like a clip. $60 upcharge if replacing the kydex sheath
Thank you!
Jo
Excellent, order placed, thanks!No problem! I just replied. They are available in your choice of black or brown.
I’m guessing these will work with the DEF2 also because I have one for the UF that works fine for the DEF.
Haha! My order is already placed.Excellent, order placed, thanks!
I should have the slickest overall UF2 setup (assuming Gus doesn't catch wind of these).
Came out beautiful and the sheath is top notch!
