TheFactor
Life is good !
- Feb 26, 2015
Unless when disassembled you can slide the pin in and with the pin having some sort of wedge that would fill the gap between the blade and the pin , then reassemble. I see what your saying though without a modified pin there’s to much space although it would still stop the blade from folding completely back on you I would think .Not sure about the custom AD-10s, but on my 4-Max and CS AD-10, there is a space between the hole and the blade, meaning that a pin wouldn't actually make contact with the blade, so the blade can still move a bit before it hits the pin. So it may add some safety if the blade were to disengage for some reason and start to close, but it's not going to wedge the blade open to call it a fixed blade.
