Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
It will do what you need it toGreetings all..!!!
Any constructive comments (pro or con) on the 6" Cold Steel SRK 3v will be appreciated. Need a knife to take up into the mountains with me. Thanks.
SRK in any steel is a good knife. You might also look at the SRK Compact.
No motivation after 40 hours of sharpening? Weird.I bought one in 3V. I had to do over 40 hours of sharpening to reduce the bevel to 19.5 degrees from 29 degrees on each side of the blade. I would have preferred going to 19 or 18 degrees, but I ran out of motivation
Yup, that’s 40 hours of using stones, including the 50 grit diamond stone that KME calls, “the beast”. 3V steel is tough, it took forever even with the beast, and then I had to re-reprofile the blade after the beast because it chewed up that edge something fierce. Never again.No motivation after 40 hours of sharpening? Weird.
Seriously tho - you should consider coarser stones/abrasives - that’s WAY too long. At $20/hour (current minimum wage for fast food employees in CA) you could have just bought yourself an $800 custom with a proper edge.
Re The SRK - I like the design for the money, especially as a fighting/combat knife, but I’ve seen video/reports of a couple of Trailmaster handles separating slightly after chopping, so that’s why I’ve avoided this type of handle from Cold Steel.
Consider checking out some of the offerings from Scrap Yard knives. Not much more money but I recon the handles, while similar, are more ergonomic and durable for utility/woods use.
But man, that finished and even 3V steel results in a very sharp blade. I like the steel, and CPM.
