who knows what the quality control for speed of grinding and heat treating is over there.
Let's say you sell a VW Bug. The person you sold it to then advertises it for sale, but says it has a Porsche engine. Are you still responsible?Cold Steel should. It is ultimately their responsibility to set the standard and make sure things come out right.
Thought I’d write a little review after putting it to its intended use (gutting, dismembering and skinning game). Bottom line: the S35VN blade is pretty much crap. I have my doubts that it even IS S35VN. It is supposedly heat treated to about 61. The knife I had for comparison is a white river, also S35VN, treated to 58-60. No exaggeration here, it held an edge at least 5 times, maybe 8 or 10 times as long as the Cold Steel. The 2 blades were sharpened to the same angle, etc. I have a half dozen 440C blades that will put it to shame and I’m thinking that a couple of my bargain basement AUS8 blades will outdo it. I was wondering about this knife because it felt a lot "grippier" when touching up on a ceramic, but I REALLY wanted to like it. One other small aggravation about it is the gap between the blade and the lock bar when open. It tends to collect gunk in it then it gets transferred to the locking surface of the blade when you close it. I could live with that if it could skin more than 1 square foot of hide without getting duller than a hoe.
Huh! That’s interesting. I’m sure I’m not as read up on steels as a lot of guys here so I never heard anything really bad about S30V or S35VN, only that adding the niobium and what not supposedly made S35VN slightly less chippy while holding an edge just as long. I’m happy with my other S35VN blades but in my experience they’re only marginally better than good old 440C. And while there’re plenty of claims out there about other super steels skinning whole elephants and still shave hair, I’ve never seen one. Back to the cold steel tho, I’m thinking bad HT or even that I got a knockoff
Keep your eyes open. They occasionally come up on that auction site. Also, post in the "Wanted to Buy: Knives" here in this forum.Well, live and learn I guess. Looks like there’s one in XHP in my future if I can find one
So are you thinking bad heat treat or are you thinking clone at this point? Or maybe this is the way the CS S35VN is supposed to be???Well I had to do a test to make sure it wasn’t my imagination. I sharpened the cold steel and the white river at the same angle to 2300 grit on my edge pro. At that point they felt equally sharp. Then I played around w a fine ceramic to get rid of the tiny burr and put a bit of a micro bevel on them. 4 or 5 very light stokes per side and the burr was gone on the White River. It took a long time with the cold steel. The burr flopped from side to side forever. I then took light strokes across green moose hide then started slicing news paper till they wouldn’t cut it cleanly, switched to stiffer notebook paper, then finally printer paper that was stiffer yet.
The results:
Cold Steel: 10 stokes it wouldn’t cleanly slice newspaper. 35 and it wouldn’t cleanly slice the notebook paper, and after 65 wouldn’t slice the printer paper.
White River: 55 stokes till it wouldn’t slice the newspaper, 130 before it failed on the notebook paper and 210 before it wouldn’t slice the printer paper.
I didn’t expect THAT much difference.
What is this White River you speak of? Link? Thanks.Well I had to do a test to make sure it wasn’t my imagination. I sharpened the cold steel and the white river at the same angle to 2300 grit on my edge pro. At that point they felt equally sharp. Then I played around w a fine ceramic to get rid of the tiny burr and put a bit of a micro bevel on them. 4 or 5 very light stokes per side and the burr was gone on the White River. It took a long time with the cold steel. The burr flopped from side to side forever. I then took light strokes across green moose hide then started slicing news paper till they wouldn’t cut it cleanly, switched to stiffer notebook paper, then finally printer paper that was stiffer yet.
The results:
