- Apr 27, 2012
Dude I’d appreciate that a ton!I'll proximosmarcosaximos for you, if you'd want me to!
It would definitely get a ton of use around work and the house!S78 really needs one and I bet that he'll use the crap out of it. In fact, Nathan had guys like S78 (tradesman) in mind for this pattern not a namby-pamby like yours truly![]()
Thanks bud!
I appreciate the help once again!No problem and I'll do my best for you Bud... You, Grog, Dave, Justin and I go way back to our days over there-there. The original posse if you will![]()
You don’t just wear them backwards on your left side!?!?!?Question...
Out of the two sheath styles available, which one looks like it could be modded to be used as a left handed vertical carry?
I have eyelets so adding a few holes to level a clip out is no issue.
If I end up loving the knife, I’ll purchase an aftermarket piece from one of our go-to guys.
Question...
That’s what I typically do.
Except at work - then I carry a fixed blade in the left thigh pocket of my carhartts.
I was going to get a Joufuu left handed ISP scout sheath (probably still will) but “modified” my stock sheath for the time being.
View attachment 844318 View attachment 844319 View attachment 844320 View attachment 844321
It’s not pretty but it works perfectly.
I cut it where I did so that the bottom part of the original belt loop catches the seam at the top of the pocket and ensures the sheath remains in the pocket.
This doesn’t help you in any way!
Sorry.
As you already know, GrogMeister is also a lefty but I don't think that he uses the standard (no pun) index sheaths he gets. He normally drags his arse in here in the wee hours of the morning, so let's see what wisdom he has to convey regarding the sheath alteration and adaptation for a lefty.
I had to post since I couldn't 'like' this ^ twice! This is exactly the type of guy the EDC is built for
Right on brotherman. I still wouldn't have at least one particular blade if it hadn't been for Bryan. One of the good guys, along with the yourself and the rest you mentioned. Except that Dave guy. Keep at least one eye on him
Matt, I think I'm getting sent out of town Friday. If you happen to miss (you won't) there might be another option. Good luck you two!
As you already know, GrogMeister is also a lefty but I don't think that he uses the standard (no pun)indexKYDEX (da*n autocorrect!) heaths he gets. He normally drags his arse in here in the wee hours of the morning, so let's see what wisdom he has to convey regarding the sheath alteration and adaptation for a lefty.
Thanks HK!I had to post since I couldn't 'like' this ^ twice! This is exactly the type of guy the EDC is built for
I had to post since I couldn't 'like' this ^ twice! This is exactly the type of guy the EDC is built for![]()
Any idea where deliveries are at from the pre-order? Can't wait to get my knife after seeing all the sweet pics.
