- Oct 30, 2015
I have been working on a compact sander frame for a while and part of that is a compact drive. After some study I selected a water cooled, 3HP, 3PH, 220 Volt, 400HZ, 24,000 rpm, 11 pound spindle motor to test. Before the switch in your brain turns to the NOT POSSIBLE position it is already a reality and not just a drawing board discussion.
The target top belt speed was 7000 SFPM and the motor had to be able to pull under the heavy pressure that a Multi Guide bevel guide applies to the belt. After more than 30 blanks ground at 5000 - 7000 SFPM in both hollow and flat grind the motor has proven that it is well capable of performing under these conditions. It also has demonstrated that it is very capable at performing the low speed grinding tasks typically performed during knife finishing.
These motors and drive are not expensive to buy new. I bought the entire package required to run the motor for $350.00 on ebay. Making a special drive assembly cost another $250.00 for prototype parts to be machined. That is pretty low. I am confident that there is not a conventional VFD solution that can match this one in terms of performance and price.
I have tested the motor and drive through most of the operations that I use my sander for during knife making operations. I would be interested in hearing what operations other knife makers might like to see tested on this drive.
Also I would invite those with real knowledge in this particular area to constructive critique the demonstrated performance, and the design as shown in the development videos in the playlist below.
https://m.youtube.com/playlist?list=PLthW154g2QNNalPz0XA4gVKsJLoQe8Mpo
