I only use the Tsprof's now and that's about it the KME short stones make it almost useless if you want to sharpen anything at all in a short amount of time and the rubber always come's off the jaws on the KME as well or at least mine always did.
Also after reading this I seen what Bladegunner was saying about uneven bevel's and I have never had that problem myself,it is possible on some knives depending on blade shape that the bevel may be a tiny bit uneven but it should not be enough to matter or that's going to really stand out,I know a lot of it has to do with thinking outside the box for example when using the double clamp's on some knives you better off putting both clamp's on one side of the crossbar and keeping the tip as far over as you can get toward's the center shaft and the farther over the better because on some low angle knives the stone will hit the clamp the closer you get the tip if not clamped like I just said.
Also another example is I only use one of the single clamp's when sharpening knives like a Spyderco Paramilitary 2 with a shorter blade and I put the clamp as close to the center shaft as I can and then I also clamp the blade in with the tip as far over as I can get so the handle is closer to the center shaft,the reason this is done is because if you use 2 of the double clamps on a knife like a Paramilitary 2 or a Griptilian the part of the edge closer to the handle will not sharpened you you will see it as plain as day.
The reinforced spring's will not help with making your bevel's more even what happen's is with all guided system's like the KME's and K02's is that the angle change's by about 1 to 3 tenth's of a degree witch is nothing the more you move off the center line or the central shaft,with a smaller pocket knife it's not going to be a problem and even a bigger kitchen knife won't be but the longer the knife the more the angle change's but like I said at max it's about 3 tenth's of a degree on a longer kitchen knife.The reinforced spring's are designed not to deflect as much so you get a more accurate edge and what I mean by that is with the stock spring's if you push hard enough to make them deflect your changing the angle it witch your sharpening the section of the edge where the spring's deflected.
Also you can get the spring's from George at STATES his new website from what people have told me is harder to navigate,George is very good person and really care's about the customer and really want's people to be happy with their purchase,also George can get everything that Tsprof offer's and carry's pretty much everything the only thing I know he told me he has not gotten yet is the Lens kit for doing convex edge's but other then that he has everything and trust me I know because I have gotten one of every clamp they sell from George plus 2 scissor attachment's.
When it comes to what stones to buy that really depends on what kind of an edge you want and how hard is the steel your wanting to sharpen,I like the Venev stones for just about anything and everything and I also like the metallic bonded CBN stones for S110v but the Venev stones will also sharpen S110v just fine to but not as fast.When it comes to water stones I like Chosera's Suehiro 10 and 20K stones and they are under rated by about 5K on each stone they are really more like 15 and 25K from what people who really stones have told me,Congress MoldMasters are great stones for doing cheaper knives such as friends and family knives they have gotten from Walmart and if you want to sharpen them to a higher grit get the Super Fine stones they offer the MoldMasters are Silicon Carbide and the Super Fine are Aluminum Oxide and are good finishing stones.
I'll try to post a picture of the best way to clamp in a shorter bladed pocket knife using a single clamp.
Thanks! which model is best? Looking at the lite version but not sure which is the best one to go with. This also seems compatible with multiple stone manufacturers (quite possibly kme as well?) What stones do you use aside from the ones it comes with? As for the springs, can I get them from statesllc?
Do you still find yourself using the KME for anything now that you have the tfprofs?
