expidia1
- Feb 18, 2018
Opinions please . . .
Background: I purchased a large Sebenza 21 CG raindrop handle here with a Damascus blade.
The owner damaged the blade by stropping and hitting the sides leaving shiny parts. Note: the lower blade is darker and the pivot area shows erosion because he acid washed the blade trying to repair it without protecting the pivot area. The acid wash also removed too much metal changing the blades CRK tight tolerances.
So before he was to resell it he sent it back to CRK and they put a new $300 blade on it.
I bought it from him sight unseen. What I did not know is that CRK replaced his blade with a Chad Nichols version which is the only one they now use for their large Seb. 21's.
I called them and asked if they had any Devin Thomas blades still in stock and they said no.
My issue: I happen to prefer the bolder raindrop design of a Devin Thomas blade rather than the tighter design of the CN.
See the two blades pictured together the lower one is the DT.
Also check out the pic of a new one offered on Ebay with the wood inlays. Check how it's all blurry from the angle they dumbly took that pic.
I personally can't see myself paying upwards of $200 for a Damacus blade that its pattern can only be enjoyed from certain angles, so I re-sold the Raindrop CN version here and also re-sold the DT blade that the owner damaged.
Between the two blades CN vs DT designs . . . Since I was able to view them both together in my hands, my issue with the CN blade was I had to view it at a 45 degree angle just to see the full Damascus pattern. As soon as I rotate this CN blade slightly the pattern started to get blurry and just turned to looking at a grey blade.
The DT blade does not start blurring away its pattern as much as the CN did (and its a bolder design which I prefer).
I think one of the issues why the design starts disappearing is because that the Seb 21 blade is not flat, it is very convex (which is part of it's extreme beauty of it's blade design).
I just picked up a Gold Class BM Foray with a beautiful bold Damasteel pattern and the Damasteel design does not start disappearing when rotating the blade (but the blade is not curved like the Seb.). I also had a DT Damascus Mnandi which was gorgeous, but too small for my tastes, so I re-sold it.
So now I'm still in the market for a Large Sebenza 21 with wood inlays and a Devin Thomas Raindrop blade.
I ask for opinions, because I like a Damascus blade but I'm not mentally locked into just Raindrop. If you own a Devin Thomas Damascus blade in a large 21 and in another pattern does yours turn grey and blurry when you rotate it?
Which pattern doesn't do this as much (I don't know maybe they all do it because of the 21's blade curvature).
In the threads, I see CRK was producing some of their models with Damasteel. I'd like to buy a used DT 21 now since its my only choice and then if CRK starts offering Damasteel in a 21, I'll flip the one I bought for a new Damasteel 21 version.
But for now, I don't want to keep buying 21's just to try different DT blade patterns.
What say you?
What say you?
