Wowbagger
- Sep 20, 2015
Thank You .never hit bones or hard things knives are no good at cutting.
"Otherwise it appears that 600 grit did marginally better than 320 or 8000 grit. "Clearly the 600 grit edges performed better than the 8000 grit edges....
Maximizing Edge Retention - What CATRA Reveals about the Optimum Edge - Knife Steel Nerds
Thanks to Ed Schempp, Matus Kalisky, and Chin Lim for becoming Knife Steel Nerds Patreon supporters! Your support allows us to fund CATRA studies. CATRA Update 1/6/2020: I have since written more articles about CATRA looking at the effect of steel type: Part 1 and Part 2 Cutlery and Allied...knifesteelnerds.com
I'll ask again :
Since we are all about cutting sand paper (pig skin and sand impregnated cards ) :
This is from Dr. Larrin Thomas's testing at Knife Steel Nerds
Importance of Edge Geometry
Another important caveat before we get to the ratings are that these are for the steel only. This does not predict which knife will cut longer or be more resistant to chipping. The reason is because sharpening and edge geometry will also greatly control properties. For example, see the chart below for how much edge retention can change with edge geometry for a single steel (in this case 154CM and CPM-154). Using 10 dps sharpening (20 degrees inclusive on the chart) leads to about 5x the edge retention of 25 dps.
I'm only glancing here ; I have little patience with it .
Before I did that I read in the quote above "clearly 600 grit did better than 8000" . . .
I was thinking I remembered 120 did the best and it seems that was correct ~ 1000 cards cut . Misprint ?
anyway ; I tried 120 edges (or I'm thinking now Shapton Pro 220 edges , stropped or Sharpmaker Ultra Fine corner of rod lightly run on the edge after)
HATE THEM
all kinds of junk hanging in the "teeth" of the scratched up edge .
Not for me .
I'd rather sharpen more often .
Stropping compound on a buffing wheel doesn't sound like a toothy edge anymore. It was probably repeatable though.It's no misprint,
The test at 120 grit was done to kinda show me that very coarse and thin would win. The operator kept talking about a much coarser and thinner edge so we went to the factory floor where the edge was sharpened by an employee using a Norton blaze belt and deburred on a cotton buff with unknown compound. This is not an edge you can create by hand, it just won't be the same.
I speculate that it is not length or surface area but rather the volume of steel that needs to be worn off before the edge is smooth.Toothy edges last longer because there is more surface area along the length of the edge, which creates a larger/longer cutting surface that takes longer to wear down.
Do you happen to have the link to this? I was hearing about this recently and would be interested in taking a look.with a photo he shared in a post here about what a toothy edge looks like. Instead of a saw tooth edge where the scratches from the coarse stone meet a keen apex, it is far more likely the apex is missing having been ripped off leaving a blunt face.
My own experience is that leather wheels and even belts do seem to over polish quickly when used with compound. A gentle pass or two to knock off a burr is usually fine and will leave some tooth, but I find it very easy to over polish if you have a stubborn burr that requires more attention than that. That's my anecdotal experience anyway, and I'm willing to bet that there is some combination of pressure, time, and compound used that would exacerbate things. At any rate, I am finding that I prefer felt belts for my deburring, and that I have an easier time keeping tooth on that media.While there is a given level of Polish it's not as extreme as you might be thinking. It's quick passes to remove a burr, not to polish the steel. I dont know what combination of wheel and compound was used but it didn't really polish, kinda just cleaned off the burr leaving a very coarse and sharp edge. It's a method I'm guessing was used for a long time before they went to automated sharpening.
I moved from an EP Apex to a TS Prof K03 some years ago. Love the blade table on the EP, but the rack and pinion angle adjustment system coupled with the arm mounted angle cube on the TS Prof have become indispensable to me in getting consistent results while chasing the ultimate edge. If EP ever integrated such angle adjustment features, I'd probably go back as I do prefer the blade table.My BESS tester has taught me more than anything else about sharpening. I know it isn't everything but I like to quantify sharpness with a number so I can make a change to my technique and see what that does to my sharpness number. It has taught me that many of the tricks I used to make a knife sharper made it duller. Raise the angle .05 degrees for the last stone to make sure I am cleaning up the apex, WRONG! Double or triple the strokes needed, WRONG! Back up a grit because I think I should have done more strokes with it, WRONG! I would never have figured out these things were bad without the BESS tester. Right after the BESS is a really good microscope. Both have been very, very humbling.
To the op, using a motorized sharpener changes your technique considerably compared to manual sharpening, either freehand or guided, so be careful what advice you take. The change in speed makes a big difference, I think the biggest may be that coarser abrasives leave a finer finish. Perhaps my biggest suggestion would be don't bother with anything finer than 1 micron. My microscope tells me anything finer generally causes more problems than benefits, even when going to great extremes to avoid contamination, including not using leather as it is too contaminated to begin with. Same applies to felt as how do you clean it?
I really question raising your angle for the leather or felt wheels. They are soft enough that you will convex your apex anyway.
Nope and I have wanted to find it for a few years now.Do you happen to have the link to this? I was hearing about this recently and would be interested in taking a look.
I used to do this too, until I discovered it raised my BESS score around 40+ grams. Even .1 or .2 degrees is enough to screw up the apex, often even with a strop. I think it is from increased point loading.I find that I get the best repeatable results by raising angle .5° for one deburring pass per side on my finishing stone.
Have you seen anything under the microscope that suggests this? If it is the case that it is point loading, then I gotta think there is a certain sweet spot to hit, or a stropping technique that can correct it. I've really been reluctant to part with the $200 something dollars for a BESS tester, but now I'm morbidly curious if I would see the same with my edges.I used to do this too, until I discovered it raised my BESS score around 40+ grams. Even .1 or .2 degrees is enough to screw up the apex, often even with a strop. I think it is from increased point loading.
Not really due to the narrow band of focus and viewing angle constraints. I think the apex is incredibly fragile and very easily damaged, and there is a lot that will damage it that we don't think much of. The more you try to refine it the more of an issue this is, but still critical to BESS scores even with an 80 micron stone. If you are actively trying to improve your sharpening, a BESS tester is very important to further your knowledge. Most of my use of it is to see what I am doing to my knife with the current stone, not so much what the ultimate sharpness is at the end.Have you seen anything under the microscope that suggests this? If it is the case that it is point loading, then I gotta think there is a certain sweet spot to hit, or a stropping technique that can correct it. I've really been reluctant to part with the $200 something dollars for a BESS tester, but now I'm morbidly curious if I would see the same with my edges.
ETA: now that I mull it over more, this also brings up questions about BESS scores vs practical use. Raising angle prioritizes removing the primary burr. Even if that diminishes BESS scores, in theory, it could lead to a better edge. How certain are you that your techniques are not in fact creating a very microscopic wire burr that would improve BESS scores at the expense of real world performance? Have you developed practical cut tests to account for this?
Somewhat unrelated follow-up question: how much influence does primary geometry have on BESS results? For instance, I can sharpen my axes to a hair splitting edge as well, but would the overall BTE thickness greatly skew the results up into the 200 range or something?
