David Martin
Moderator
- Apr 7, 2008
Thanks unky for the assistance toward a fellow Forum members. A gentleman act. DM
I started with feathers and used them exclusively for my first 6 months. I've since switched to Astra Supers (green), and I love them. They are a lot cheaper and plenty good.
That said, if you are starting wet shaving, I have to differ with Unk on this one. I am 100% against blade sampler packs. If you are a new wet shaver and you are having irritation or any other problem, how do you know the problem is the blade? How do you know it isn't your technique or something else? I suggest picking one quality blade (all the suggestions here are good, including the feather... which some people say you shouldn't start with, but I started with them) and stick with it for at least a month, ideally longer. Once you have your technique down, then you can branch out and see what products you prefer. I only advise against Merkur blades. They seem to be universally canned on the wet shaving forums, and they are very expensive, to boot.
There is absolutely no way I would have put up with the irritation I was experiencing for a whole month without trying a different blade. While swapping blades every day to try and 'chase the dragon' wouldn't be as productive as correcting poor technique, it wouldn't hurt to see if a blade change helps.
I can't think of a reason why someone would take Unky's advice on trying different blades to alleviate an issue but ignore the basic advice given to beginners all the time: Start with good equipment and get your technique down.
In your case, it looks like you guessed correctly and fixed the problem with a different blade. That's great. I'm curious as to how you knew the problem was the blade if you had only been wet shaving for a month. I'm also curious as to what the first blade was that was so terrible, and what the new blade was. Also, what was the problem with the first blade? Was it pulling? Was it too sharp?
When I returned to DE shaving after decades in the cartridge indoctrination zone, my technique wasn't at all good. Pressing too hard due to being used to light flimsy razors, however, that very soon corrects itself and for obvious reasons!. I re-learned fast. Nevertheless, I experienced great differences between blades some good, some worthless some outstanding. Hardly surprising as our beards are individual and will respond to different blades differently, no technique skills will alter that. Some toothpastes suit my teeth, others cause problems and it's not technique there either. Likewise soaps/creams some work well for me but badly for other people, it's not my lathering skills (clearly that can play a role if you are inattentive or pushed for time) but my skin. Many people rave about the Turkish soap Akro, certainly whips up effective lather but leaves me with spots and I can't stand the WC cleaner smell!
Sampler packs, blades or small soap/cream samples are a good idea and encourage people to enjoy DE shaving.
Regards, Will
I don't know much about the Parker line, but I don't think they are bad razors, I just wouldn't buy a new razor on Ebay. If you want new check out West Coast Shaving if you want inexpensive look to the vintage razors. I still wouldn't buy as quickly from Ebay because the prices can be inflated if you don't know what you are looking for, same thing goes with antique mall. There are still good deals to be found on both, but for me the best place to find inexpensive vintage razors are at flea markets and the occasional yard sale. Just don't expect to find perfectly clean razors at either, they will be covered in soap scum:barf: but it cleans off easy enough. The older razors are usually nickle plated brass, much more durable than new razors, but if it has a lot of green corrosion on it, badly bent teeth or missing on open comb or a safety bar the is bent walk away its not worth it unless it is free.
A really good starter vintage DE is the Gillette Tech, there are lots of them out there, they are cheap, and very mild. West coast Shaving will cover you for your blade, soap and brush needs. Canned goo just wont give you the same results as a good shaving soap and brush will. Budget in the $100 range for start up cost, you can do it for a lot less, but in that $100 range you get things that will last most of your lifetime even if you are a teen just starting to shave![]()
