- Jan 26, 2002
Received 18" Gelbu Special by Kesar yesterday. Shipped Fri, arrives Wed.--not bad.
Pala is nuts giving these away this cheap!
Daym, same weight (22 oz) as my 15" AK but somehow feels much lighter in the hand, almost lively. Like it could turn around and take a nip at you. Even though handle is made of presumably lighter wood. And the wood will be beautiful once that red goop is off. Karda and chakma were OK, a little rough near the handles, but cleaned up pretty well. May stone the flats if really bored. I have sanded the handles down to begin to "Walosify" them before I tackle the big handle. One has very nice almost gold wood with dark bands, the other is kinda a pale brick red color with less contrast, but with the oil, looks more golden-colored already. I can't wait to get the khuk handle sanded down.
The khuk is very well executed, one side of the blade is perfect, the other has the tiniest fold in the tip of tip of the fuller, and a ripple there where Kesar probably tried to pound it all the way out. Otherwise it's beautifully smooth. The cho's a little wonky, but a jeweler's file will fix that right up. Not surprised at this with the closed type. Polish was fantastic, I almost didn't want to finish sharpening the pretty good edge. (It had an even burr all the way down one side!) I managed to get a decent, but not quite equal polish back by hand, finishing with green honing compound on fine carborundum paper. Seems to cut pretty fast but leave a decent polish behind. Some old shop vet will probably tell me that I'n nuts, or that this trick is old as the hills and twice as dusty. And then tell me how to do it right.
The butt cap and the smaller piece the tang goes through are perfect and the bolster has a nearly undetectable seam, save for a couple of tiny,tiny dimples. Darn near jewlelery-quality soldering.
The even fuller and uniform decrease in blade thickness to the thin bevel from the thick spine is really most impressive. Just a few chops on the hardwood log so far, and its awesome. I can see why this pattern is a favorite.
Quite the bargain, overall detail and finish on the khuk is a notch or two above my AK for sure.
The scabbard looks like it had an encounter with an angry chappe, but that and the inconseqential, now removed, rust spot sure don't bother me when I pick up the knife.
Oh, and the small tool loops had some leather glued over the tack heads so handles don't get scratched--a nice touch.
The wood handle seems quite a bit more round in cross-section than the horn one on my AK--typical, or just normal variation???
