David Martin
Moderator
- Apr 7, 2008
I'll try it again. http://blog.modernmechanix.com/wond...spected-facts-about-razor-blades-and-shaving/
Try seeing how you come across. DM
Verhoeven conducted the leather experiments on flat hones and flat leather strops, using this jig, leaving the specimen blades attached in the jig during the entire honing and stropping progression:
(picture taken from page 18 with reference to the original article at http://mse.iastate.edu/fileadmin/www.mse.iastate.edu/static/files/verhoeven/KnifeShExps.pdf)
He checked his results at 3000X magnification, using an Scanning Electron Microscope, and found no discernible diminishing of 6000 grit abrasive grooves.
That is as scientifically bulletproof as it gets. Verhoeven had to change his mind about leather: "(...), it was initially thought that a clean strop would contain enough natural abrasive material to produce a marked improvement in the quality of the edge. As a result, several initial experiments were done with clean leather strops,including an experiment with alternate 3 cycles of 4 leather stropping plus a single 6000grit sharpening. In all cases the clean leather stropping proved ineffective in comparison with the dramatic improvement found with the chrome oxide loaded strop." (page 22 of same document)
...yet what members really wanted to do was slam it. Plus, never present evidence of their own.
Stropping a razor on a clean leather strap remains one of the most scientifically uncharted territories of the sharpening proces. In his - among sharpening adepts famous - knife sharpening experiments, Professor John D. Verhoeven of the Iowa State University ventured into some sideways research on stropping, but he could not reach much conclusive insights into the bare physics of stropping a knife's edge on leather that was not treated with any abrasive compound. Even though he inspected the edges with a Scanning Electron Microscope (SEM), he reported little to no evidence of physics at work. One could be inclined to start wondering whether stropping has any measurable effect at all. Yet, any experienced straight razor shaver will testify that the difference between a regularly stropped and an unstropped edge is very conspicuous. But even for those who like to attribute this to the mother of all placebo effects, it's impossible to dismiss the very clear improvement that can be found post stropping, in the way a single free hanging hair can be severed at any distance of the holding point. In short: while we can collect empirical evidence of stropping efficiency, we cannot witness the bare physics at work. That leaves us wit a lot of speculation.
Apparently, the natural abrasives in clean leather,
on either the hard or soft side of the leather, is not adequate to produce a significant
abrasion of the surface.
Plus, I've been on many discussion here which had well supported evidence put forth yet what members really wanted to do was slam it. Plus, never present evidence of their own. So, I don't take the bait any more. DM
Here's some evidence on stropping dating back to 1931. http://blog.modernmechanix.com/2008...spected-facts-about-razor-blades-and-shaving/
gadget, What I saw from the photos, supports your point 1&2. The article I submitted on stropping actually states this on pg.55 last paragraph, almost in your wording. On your point 3 I don't know. On your point 4, yes and much quicker than one might think. Like after 200 on a spongy material like leather. Still, is this a good or bad thing.--- I'm not sure. I'm currently shaving with a Feather blade (double edge) and its on shave #50. Is it convexed? Yes, but not as much as I've seen on my straight razor from stropping on plain leather as the double edge only sees stropping on paper backed with a hard surface. My experience, your mileage may vary. DM
I just did the modernmechanix link and it loaded right up with one tap on the touch pad... ? DM
razor or any other cutting tool doesn't have a very thin apex. It's what sharp is. A triangular edge that draws out to Infiniti. When you use that tool, the very apex of the edge is "damaged" or rolled or chipped this getting dull. Whether you call it a fin or apex of the cutting edge is redundant because every knife or razor has one. What do you think I mean when I say fin?
