Way-Barney
- Jun 4, 2023
Thanks for the reply Tom,I would cut it up into blocks and have K & G stabilize it. Looks like the wood has a lot of figure in it. Should make attractive handles.
Flipping heck, you have all got me looking at vacuum pumps, tanks and resin now I reckon that I can be set up for 300
I have tracked a company down that does it, I have e-mailed for a quote see what they say.I'd be inclined to send it out despite having the equipment here at home. You can't readily do at home what a place like K&G does. They use extremely high pressure in addition to vacuum. You'd be looking at the "other" type of stabilization with a different polymer like "Cactus Juice". Not the same chemically and quite a different "feel". Study carefully; home stabilizing can be a PITA and you likely won't end up with something that feels like the plasticized wood of a hi-pressure impregnated acrylic stabilizer, should that be what you seek.
yes, its their product.Is that Novawood Germany?
They have a good name
My name? Bartyes, its their product.
PS
what is your name?
All I can say is that Novawood from Germany has a good reputation. I haven't used their wood myself yet.would their product be quality Bart?
If you're using them on full tang knives just cut them slightly longer than the length you plan on using. The 1 1/2" width should be no problem for stabilization. If they're for pocketknife handles a length of two or three handles plus a bit more for overrun would be fine. You can cut them to the required thickness when they come back. It really depends on how big their vacuum chamber is though, they may be able to stabilize a foot long piece with no problem which would be best as you can then use it for multiple projects. K & G has done a number of foot long 2" square pieces for me with no problems and I'd imagine Novawood probably has the same capacity. I'd ask them before you do any cutting.would anyone be so kind as to show me the best directions to cut it.
the first one is about a foot and the second 10".
both are 1 1/4" thick
