A motor running on a VFD will sometimes have a band of vibration when running on bench with no load. Once you've got on 2X72 that provides enough load to smooth motor out - most of time. If not you can always program the VFD to skip the freqs that give vibration. I've never had to do that with any of the cheap Chinese VFDs I've got. Programming VFD to display belt speed in SFPM is one of the things I really like about the VFDs with display.
I put off buying a mill for 3 or 4 yrs, just didn't think I'd have enough use for a mill. Now I've got a mill I don't see how I got by without. Just like the lathe, always using for something you'd never thought of before.
I think the cooling tower mention was from industrial days when Fitzhugh was using VFDs in industry. Cooling tower fans where a popular use to save power. With the mention of reactors I suspect there were some long motor runs also, and had to worry about standing waves on the motor power leads. The last chemical plant I was responsible for I passed on use of VFDs because I had some 500 to 600 ft distances from MCC to motor. The problems of long distances just didn't justify use of VFDs. AND getting the expensive armored/shielded power cable made the use of VFD not a good choice due to cost.
Good to be retired {yea, I'm bragging}
