- Feb 5, 2013
I'm with Ken, it all clicked when I saw where you are mounting it. The cam design is looking promising. It's a good sign when something is simple enough that it seems obvious... but of course only once somebody else thinks if it
3/4 spacers... Not sure I follow. Are you using 3/4 tool arms? And heirloom fit I'm going to try for a perfect fit but will end up having to call it "rustic" and act like I intended it that way.
What height do you guys like the center of the platten or contact wheel at?
How much force are the risers really subjected to?
For example, with the tracking wheel halfway between the tension pivot and a 40lbs gas spring, you'd have 80lbs belt tension on the wheel and 40lbs on the pivot, some mix of forward and down, right? (plus some torque from the wheel being offset).
I had not thought about moving the pivot point on the platten trunnion, that frees the design up a good bit.
