Fitzhugh, be careful with a router jig. I think you would be better off drilling a few holes and connecting them with a fret saw and/or file. I have had some pretty scary kickbacks with a router both on wood and aluminum, especially on the router table. I particularly do not like cutting slots. Spiral up-cut bits seem to do better, straight flute bits always pack the slot full of sawdust.
I did the math, at least a quick approximation using a knife edge instead of a plate to push against. I could not wrap my head around how to compute the cam shape having a fixed tangent as a constraint. I will look at it again tomorrow. With the lever going through a 120 degree arc, the numbers I tossed out earlier should work for friction coefficients in the 0.1-0.25 range. So, unless there is grease on the cam, it should lock with a good safety margin. Obviously, the larger the cam the better. There is also the option to make the cam lift more rapidly through the beginning portion of the arc where it does not have to lock. I think this would allow for a smaller cam that still locks where it matters. There are some space constraints, but I think I can get the cam near the tracking arm pivot point by using a bolt through ball bearings mounted in a support on one side of the arm only. The cam could then swing past the tracking arm pivot point on the other side. Sometimes, I really wish I knew CAD, but every time I attempt to learn it I find it so much quicker to just make a sketch by hand.
I think the Northridge and KMG TX both use a ratchet without any springs. The TW90 has a spring, but it appears to me that it must be very stiff and not allow for a lot of displacement. I might be wrong on that. I am also not sure that the system is necessarily short throw/stiff spring. This depends not only on the stiffness of the belt, but also on the change in path length generated by the rotation of the tension arm. It seems to work for many different geometries and I think you would hear a lot of complaints if belts popped off in use because the belts stretched a bit.
If I can figure out the cam geometry, I will find some time this weekend to make a prototype out of plywood.
