It's a rainy dark day here, bad for photos, so I'm pushing those back to tommorow. I'll do some comparison shots with my Izula and Mora clipper as common reference. I wish I had an RC3 to compare it too, obviously I don't have my forum knife yet.
Here is my review, it turned out long'ish so I put keywords in bold for the aid of any attention span deficient among you.
This knife has several gee-whiz nifty features which distinguish it from similar knives. Lets get them out of the way first, starting with the bad news. I really don't like the
bottle opener. It is exactly where I want to put my thumb for several cutting tasks. [pics to follow] It's not a horrible flaw, but I don't think such a minor function is worth the cost to ergonomics. On the other hand, I think if you took the coating off there to expose a square steel edge it might make a nice notch to strike a firesteel with. If it had two functions I'd give it a thumbs up.
The
wire breaker notch works and has no drawbacks. It's so simple! More knives should have this! I was worried about the
pry bar pommel being uncomfortable, but it really isn't a problem. I can imagine using it to pull nails or staples, or as a scraping tool. Also, having that definite hook at the pommel aids in drawing the blade. I like the
handle compartment. It measures approx 0.4" by 2". I found with some disappointment that a Spark-lite would not quite fit. If this HEST were mine I would probably put in a plastic bag, a couple chlorine dioxide tablets and some emergency money.
Now on to the main features.
The overall size, feel and balance of the knife is very very good.
The size is nice, exactly 3" of cutting edge and about 8" overall. A versatile size, big enough for most tasks, but small enough to be conveniently carried. The balance point is just ahead of the first handle screw, in the exact middle of the knife.
The
blade is hefty for a knife this size, about 0.18" thick at the spine, significantly thicker than the only slightly shorter bladed Izula. It is also wide about 1.25" from spine to edge at it's widest. This knife is built VERY strong. That thick wedge batons kindling size wood very efficiently. But, there is no free lunch, making a small'ish knife that chunky has some drawbacks. It makes some minor cutting tasks a little less convenient. For example, quartering an apple; even with a razor sharp blade the cuts took some pressure. Obviously this is not intended as a kitchen knife, so judge that observation's relevance for yourself.
The
handle seems just a little small to me in a saber grip with my thumb on the ramp; it leaves my pinky hanging a bit (My hands are almost exactly statistical average for a man). This is not a major complaint, I'm grading on a curve here; I only mention it because I think the Izula has
amazing ergonomics for it's size. The HEST's ergonomics I would describe as 'good.' For precision cutting you can
choke up on the blade a LOT very comfortably, in fact that seems to be the most intuitive grip for me with my thumb far up on the spine past the jimping and bottle opener. [pics for this coming too] Reverse grip is very comfortable.
The knife makes a fine
fire prep tool. I used it to carve fatwood curls, scrape dust and spark a fire with a minch metal ferro rod. It worked quite well for scraping the dust with my thumb on the wide flat of the blade, and it made nice thin curls.
It's nice to see a kydex
sheath. I note with interest that this one is screwed together, most I've seen are riveted. It's got a drain hole, which is good. It's a bit of a paddle though, almost 3" wide and 4.5" long. I could see some folks wanted a smaller one, particularly if they want to EDC their HEST...and aren't strapping on web gear every morning.
Overall, the HEST is a very good knife with some interesting and unique features. I think I'm going to miss it when I have to send this one off to the next guy in a day or two.
p.s. ouch, it just bit me. Missed the sheath opening and stabbed my palm slightly.
