Are you going to do a spine whack 'test' right away? How important is that test to you?Have you had any issues with the lock during normal use or otherwise? Otherwise being "spine tests" Just ordered one and I'm hoping I get the same performance!
I may put up to moderate pressure on the back of the blade to see if it folds and I may tap the back of the blade on something to see if it folds, but I don't want to hit it hard and damage it.Are you going to do a spine whack 'test' right away? How important is that test to you?
You are going to be putting pressure on the spine during regular use? I would just say, I would 'test' on the back of your hand with some light pressure. If you're determined to do "spine whacks" I would use the knife and let the lock settle before doing that.I may put up to moderate pressure on the back of the blade to see if it folds and I may tap the back of the blade on something to see if it folds, but I don't want to hit it hard and damage it.
It is only important if it seems like an issue I would encounter during normal use, but I am not going to test it to failure.
That is what I had in mind. I've never had an issue stabbing, cutting with a liner lock, even with cheaper knives. I will test it and see if it passes what I deem "normal use".You are going to be putting pressure on the spine during regular use? I would just say, I would 'test' on the back of your hand with some light pressure. If you're determined to do "spine whacks" I would use the knife and let the lock settle before doing that.
Is using a knife to cut wood considered hard use? We used to have to do the same thing in boy scouts when I was a kid with a Swiss army knife and never had anyone break a knife or have it shut on their hand."Hard use" is a spectrum and I'd agree that past a certain point, it's better to go with a fixed blade. Some folding knives are sturdier than others. Some can withstand more force against the locking mechanism than others. They're all still folders. It's like the difference between a gate and a wall during a siege. It needs to be strong but don't expect miracles.
I was doing a little research on heavier-duty folders recently and I heard good things about the Tuyaknife Bruiser and Talisman. I don't speak the language but here is a fun "hard use" video of the former:
