Hey Daniel in the first pic it looks like you you used a torch to heat the back end of the frame, why did you do that? is it to make it more stiff? I ask because I am working on a frame lock and am about ready to cut the lock, do you think that if I heated the part that contacts the blade that it would give it more wear resistance?
Edit: I am smoking some chicken legs right now.![]()
If I had to guess, he heated up the lock relief before bending it in, then letting it cool. That way, since titanium is a memory metal, it will spring back to that angle. Ish.
I could also have entirely made that up in my head. >_>
Chicken legs smoking!That sounds awesome!
I heat up the lock recess to bend the lock bar, after heating and bending it is set. You can bend cold too, I think the heat is better but Titanium is a somewhat mysterious metal and I hear a lot. I like to heat until it is easy to bend then heat until it stays, it seems the longer soak at red temp does something to make the metal hold a bend well. I am just in from a 14 hour day and forget the terminology! lol
Those chicken legs sound good, I am into my BBQ!
Thanks Daniel.
Daniel- Relax... you've made it.
Lol, ramen is a tasteless canvas that can be transformed into nearly anything!
-X
