BluntCut MetalWorks
- Apr 28, 2012
Continuing on implications/deductions given a matrix has CWF microstructure. Sorry for being explicit - many of you probably easily see it and or refused to waste neuron on it.
a) Temper embrittlement mostly goes away because diffusion is nano isolated up until ferrite close & surpass percolation percentage. Weldable is its big implication. Basically heat reduce strength, increase ductitility. Unlike bainitic steel for example, where welding = embrittle heat affected area due to RA convert to martensite and rapid precip particle/carbide coarsening. e.g. Using optimal temper temperature, spring can be strong (i.e. can be thinner) and have longer service life.
b) CWF microstructure has high cohesion and congruence (I invent 'congruence' it's simplify a label in my mind, so please no semantic dance), where dimensional contraction by temperature (reduction in atom radius or electron cloud - whichever you like) won't turn into major jarring compression = dislocation like conventional ht matrix. My video in OP about W2 66+rc (untempered) blade didn't failed when chop bamboo at below -300F. Which mean bridges/infrastructure can/possibility operate in extreme cold temperature without adding steel volume and or added thermal shield.
