Thank you, Luong. Your work continues to get more extensive and valuable.
I like the idea of using a more abrasive medium than rope to test edge wear. I remember poor Ankerson's tests where he ended up with a mountain of rope cuttings or cardboard strips, sore hands and hours of lost time. Larrin has a lot of CATRA data on steel edge wear, but those data depend on expensive equipment and are limited to standardized edge angles, sharpening techniques, heat treats and Rc hardness levels, in addition to the variable of the steel alloy.
A standardized test that we could all do fairly quickly would be welcome. Of course, with too much abrasion, we lose resolution. I'm thinking that with this kind of test, edge angle and edge width are not too much of a factor. Only the apex sees much challenge as it tries to defend its width (sharpness).
It looks to me as though you are putting a lot of pressure on the cut, which focuses the edge wear on the back part of the blade where the cut is initiated and mostly, if not entirely, completed. Maybe a lighter pass that doesn't cut fully through the Scotch Brite would work better, with the pressure carefully controlled. Maybe tape a weight to the blade and just drag it across the Scotch Brite with no additional downward pressure. By using a lighter weight, you could get more resolution. But this looks like an idea that could form an easily standardized test of edge wear that we could all do.
Love the blade and handle design. Classic.
