- Jun 27, 2016
So I've recently gotten back into hand sanding and I'm taking my blades up to a higher grit for hamons than I used to. Previously I did 1200 grit paper then etched/ polished with 1500 grit SC powder. However, I was still able to clearly see sanding lines ( I could get almost a mirror via light etches and the SC polish but the 1200 grit lines were so apparent). So I have been trying going more towards 2-2.5k before etching. However, I can't seem to get the rhynowet paper to cut past 1200 grit, I used it dry, wd40, w/ water, Nothing seemed to really work. Like my clean 1200 scratch pattern was parallel to the blade and I couldn't get those scratches out by going diagonal with 1500 or 2000 grit paper, I used 2 8x11 sheets each on a 7" blade. So, do I need some diamond film paper? also just to note here I have also been trying some 2500 grit diamond powder instead of SC, dont waste the money it doesn't work well, leaves very deep scratches ( I got cheap powder off eBay so maybe it's not a true 2500 grit) idk.
For example, you can see the lines here
